Flat air chisel? Put it on the lip where the rim meets the axel?
Get a pair of scissor jacks and place between the back of the wheel & the mower body
Tighten them up to take up the play in the axel then 1/2 to one turn more
Use the point chisel on the end of the axel
If yours has a bolt then put an Allen head bolt in the hole to prevent damaging the threads & mushrooming the end of the shaft
Push as hard as you can on the air chisel then pull the trigger slowly
Some times it is easier to turn the mower on it's side
hammer away till the jacks start to slip out .
From here I like to get in with a fine wire brush, we & dry , what ever I have on hand to clean the small amount of exposed axel the some penetrating oil & tap the wheel back on
Now that there is a bit of movement  some times a hammer from behind will give a bit more, if so clean again oil again & repeat as necessary
If not then back with the scissor jacks & air hammer again
On some I have had to walk the wheel all the way off with the air hammer & jacks
On some really rusty ones that also had axel damage I had to heat the wheel red hot with the oxy torch while using the air hammer .
I try not to use the torch because that means repainting the wheels
Make sure you clean the axel when the wheel is off and liberally grease it
Then take bot wheels off every odd numbered year and regrease them
