SmallEngineHead160
I also should ad that these pulsa-jet carburetors are pretty simple to work on.
The two main bad problems I have found with them are the throttle shaft bushings wearing out and the carb base warping.
A slight warp may or may not be a problem.
Just depends on if it's warped bad enough for the gasket not to seal.
