I love my 2020 E-Series 44" Radius mower, but due to lack of any seat movement it has become increasingly uncomfortable to mow the uneven parts of my yard. On a recent trip to my Exmark dealer to check out trade-in options, the parts man recommended that I simply add the "126-9868 Seat Suspension Kit" for $385. This is the story of that "adventure".
	What the Kit does is provide a new steel plate for mounting the seat. This new plate hinges at the front and is suspended at the rear by some high-tech rubber shock units. You unbolt the seat from the existing plate and fasten it to the new plate. Sounds simple.
	However, this is ALL predicated on the assumption that the existing plate is punched to accept the rubber bumper assembly. As shown in the kit diagram (above), the plate directly above the fuel tank needs to have 2 rows of slotted holes, into which the rubber bumper unit gloves. And this is the catch.... if that plate is not there, then Exmark expects you to purchase a new Fuel Tank Plate for an additional $125 !! And that was the case with my mower. It would have pushed the cost of adding basic seat suspension to well over $500 on a mower that initially cost well over $5,000. I could hardly swallow the $400 (kit + tax) cost of the initial kit, now they wanted an additional $125 because my mower won't readily accept the kit which all the Exmark manuals suggest using. Sorry Exmark.
If you are considering this Kit, then I highly suggest you take the time to slide your seat all the way forward and look for the double row of slotted holes in the black steel plate just above the fuel tank. If those slots aren't there then you're in for a very expensive upgrade.
