pahrump-pete
- Jun 18, 2023
- Threads
- 1
- 4
I just picked up this riding mower. It has no mower deck, but I want to use it for a utility vehicle. Forward works fine. The ROS is working. When I try to put in reverse with out putting the key to reverse the motor quits. But if the key is put to ROS the motor keep running, but the shift lever only goes half way and wont engage reverse. Thanks for your thoughts!
