Carb. Linkage and springs for Husqvarna yth24v48 with b&s vtwin
Will need engine model information
Briggs and Stratton Engines model and type locator
24 hp briggs and stratton v twin model 44n877 group 0003g1. Took carbs off to rebuild, and didnt pay enough attention on linkage hookups. Especially the springs, like choke return spring, where does it attach? I think I figured out the rest but would like to verify all the linkage.
Harry, did you ever get a resolution on this? I have the same issue with the same carburetor, I'm looking for pictures of the linkages. Thanks
Here are the pictures I took on the way in. Not comprehensive but got my v-twin w 2bbl carb running well once after a carb clean and again after a replace. The throttle/choke control connects to the bottom hole on the disk below the carb (which seems to have a place to attach it for frversed function).
Erbid
Your cellphone camera is your friend on that stuff.
Erbid
Do you have pictures of the throttle springs below the carb?
