Troy-Bilt Self Propelled mower
Troy-Bilt Self Propelled mower Model # 12A-A2BU711 usually starts after about 3 pulls, once you shut it off after doing some mowing and stop for a few minutes it will not restart, so you leave it for about an hour or more and it will restart. Any suggestions.
Need time you use it and it won't restart after a couple minutes check to see if the choke is open or closed. Maybe something wrong with the bimetal thermostat that keeps the choke open when warm.
Thank you for the advice greatly appreciated. Will let you know the results once I take a look at it.
