CarlosOvelar
Please help me with my Ferris is 3000
I cant adjust the steering arms one is harder then the other one .
Can't find anything about a model Ferris 3000. are you sure that is the model ? And what is it you can't adjust ?Please help me with my Ferris is 3000
I found the model, must be an older one. But, what is it you can't adjust ?Can't find anything about a model Ferris 3000. are you sure that is the model ? And what is it you can't adjust ?
There aren't any adjustments in the hydraulic system, other than mechanical stops for the levers. At least as far as I know. I have had to deal with hydraulic issues before, and my first question is, has the hydraulic fluid and filters been changed as required ? I'm assuming that the fluid levels are ok. If not, you will have issues, maybe such as that. First thing I would do is change the fluid and filters, per the manual. If that doesn't correct the problem, you will need to take it to a dealer, unless someone else here has had that exact problem and knows the fix.Hi how are you? Yes is an older model
is 3000 2FKAV2561 when I pushed the handle bar forward the left side is faster then the right side and I can't adjust to go evenly forward. Thank you for your response.
Thanks anywayYes the hydraulic oil and filter changed recently oil level is ok .
