Cub cadet ST100 weed trimmer dying issues
RaginMad55
My Cub cadet ST100 weed trimmer will run for a bit then starts running erratic and then die. Has new air filter, spark plug, oil and fuel filter are ok. Anybody have any ideas on what else is causing this?
I know it's been a while, but I am curious as to what was the solution to your problem.
Found out that cleaning the little foam filter on the carbon canister worked. The carbon canister is located on the right side under the inner shroud above the air filter. Hope this helps.
