Denny W Smith
 - May 18, 2023
- Threads
 - 2
 - 3
I am glad to find this site as I have lots of questions on what route I should go.  I posted this a few days ago but in the wrong location I think.
I have roughly 30 acres to mow most of which is done by a tractor and a 6' bush hog. About 4 or 5 acres I am mowing with my Exmark Lazer Z AS Model # LZA27KC604, S/N 879852 with a Kohler Command Pro 27 engine, Model PS-CV740-3119, S/N 4012800281. I did mow the entire 30 acres once last fall before winter with this mower. This is my first and so far only experience with a zero turn mower. I purchased it at auction in Aug 2021 with 1279 hours on the meter. I am sure it was operated previously by a landscape contractor. It now has 1370 hours on it and this past week the engine has started to lose power under load and is pumping blueish white oil smoke out the exhaust. I am assuming it has bad valve seals or rings (I am not a small engine mechanic). A quick online search indicates a replacement engine is running about $3k. Otherwise the machine is in decent shape I think. The deck is good. My question is should I invest more money into it? What kind of hours should I expect from the drive motors or am I looking at rebuild/replacing these soon?
In comparison to repairing I could really use a 72" deck machine perhaps with a more versatile suspension system to handle the rough terrain better (property was timbered about 10 years ago and is still rough in places) possibly a Ferris ISX3300 ($18k ouch!) or something comparable with a more robust suspension system.
Should I replace the motor and sale/trade it? Buy a finish mower for the tractor instead?
Any thoughts or suggestions would be appreciated. Also, does anyone know the year of this mower via the model or serial numbers?
Thanks in advance for any replies.
