KK560
I've mowed with it at least 3 times so far this season without any problems until now. I've cleaned the carburetor, changed points, condenser, coil, regulator, check the spark plug, tried different plug wires, adjusted the governor, and it's still not wanting to run full throttle, once it's warned up after 5 minutes or so. What else should I check?
