Z925A
mike coulter
the mower will start sometimes and run for a BIT THEN DIE.
then when i try to start it , it doesn't make a sound. I also noticed that the fuel solenoid doesn't click but pulled it off and it works but not on the mower.
all my fuses are good. when it wont make a sound the amber light on the bottom right of the hour meter flashes once then twice.
any help would greatly appreciated
Sounds like the fuel solenoid connector's terminals are not making good contact with the fuel solenoid pins.
mike coulter
they are good but the issue is when it dies and i turn the key the mower doesnt make a sound or even turn over
Then you will need a copy of the service manual so you can dig deeper into the problem. You might an ECU failing.
mike coulter
Ten you will need a copy of the service manual so you can dig deeper into the problem. You might an ECU failing.
is there a way to test the controller? all i have is a volt meter.
do you think that when its getting hot it fails?
