Here is the picture of the model numberRecheck Engine Numbers nothing showing, click above & enter for Manual & Parts List.Find Manual & Parts List | Briggs & Stratton
Find your Briggs & Stratton manual or parts list easily by locating your model number and using our resources for part identification and ordering.www.briggsandstratton.com
Here is the picture of the model number View attachment 63988
No problem, I’ve looked at everything I can find and I can’t find a diagram with that part in it, I believe it’s the original fuel pumpRecheck Engine Numbers nothing showing, click above & enter for Manual & Parts List.Find Manual & Parts List | Briggs & Stratton
thanks VTX1300, MarkResults
www.partstree.com
To the left of the starter, it looks like the mounting plate is part of the dipstick tube, as you can see in the picture to the right of the rectangular plastic plate.31P677.
Briggs & Stratton 31P677-0912-G5 - Briggs & Stratton Vertical Engine Parts | PartsTree
Briggs & Stratton 31P677-0912-G5 - Briggs & Stratton Vertical Engine parts. Browse OEM diagrams and order the exact part.www.partstree.com
Not the fuel pump.
Where'd that part come off the engine from?
OkThat is the EPA vapor line/roll over protection valve that mounts into the top of the fuel tank on riding mowers.
Didn’t realize that because the gas tank is missing, could the fuel pump mount to the rectangular plastic plate in the photo or where does it mount because it’s missing as well
