Woody123
- Apr 20, 2023
- 4
I have a 2019 Simplicity Conquest Model 2691339-01. At the beginning of the season I found a mouse nest under the miter shroud. No mice were in the nest. I took the shroud off and looked for any signs of chewed wiring. I found none. I have replaced solenoid and circuit breaker next to the solenoid. I have to disconnect the power and reconnect the power either from the circuit breaker or battery for it to start. It runs fine after it’s started. I have also replaced the battery. Any help would be greatly appreciated
