I’ve got a Ferris IS3200z 72” deck vanguard engine with a little starting issue, it’s an intermittent issue, occasionally when you hit the key to start it the machine just clicks once, like the starter solenoid is bad, I replaced it and no change, also had a broken wire on the voltage regulator, I replaced it as well. Anyone else had an issue like this on their Ferris? It’s a 2019 mower so pretty new machine, I was wondering if it might be a Saftey switch or something like that? Thanks in advance
