Hammermechanicman
- Jan 10, 2020
- Threads
- 69
- 3,899
If you have a outside micrometer measure the valve shaft diameter up near the keeper area then measure along the valve stem in the area where the stem rides in the guide. If there is any difference i would replace the valves and lap them in. Unless you are planning to race the engine or the like i would not worry about the guides.
Hone the cylinder, new piston and rings, new valves lapped in, seals and gaskets and i bet you will be good to go. As Taryl would say. It's not the space shuttle. ?
