Engine won't start
superdave77
I have a general question about an engine that won't start. Ok its a Champion generator w/carburetor any help would be appreciated.
Has electric starter, it gives a good start so to speak for 2-3 seconds then dies. My first thought was I have a bad carburetor, so I bought a new one. New one does the same thing. Then I thought, did I put fresh gas in? Couldn't remember so I drained the tank and put fresh gas in, same thing. New spark plug, took fuel **** off checked filter ok. Sometimes I use starting fluid to give a good boost. I have the air filter off while doing this. All I get is the first firing for 2-3 sec then blah....
I'm at a loss what to do next.
Thanks,
david
Does is start and run a couple of seconds and then dies, and if you try to restart does it start at all or does another start run for a couple of seconds and then die again.
superdave77
Yes, keeps doing same thing every time I try, a short burst after a crank. Just doesn't want to take off.
Thanks,
df
Bertrrr
Look at your fuel source, supply side hose / tank etc. I sometimes run a new fuel line bypassing filters etc straight from a container of clean fuel - to eliminate supply side issues, is there a fuel pump involved ? These diaphram pumps sometimes go bad - I keep an electric 12 volt pump handy for trouble shooting fuel problems
