Hello all, I have a 2006 briggs and stratton 18.5 HP [31N707] engine that came off a craftsman. We put it on a small ariens zero turn. It worked very well for awhile, then got it where it wouldn't run unless the choke was on. Eventually it quit running all together. After this my dad parked it and it sat for 2 years.
I decided to try and fix it for him this year. There was water in the gas, so I took that tank off and drained it and dried it in the sun for a few days. I put it back on put in fresh gas. I also replaced the carb and all fuel lines and vacuum lines and filters. I put the choke on and started it and it ran for about 10 seconds, I took the choke off and now it's back to not running at all again. Tried tinkering with the air/fuel mix a bit, still no luck. If you feed it gas directly into the carb it will run. It has good spark, everything else seems to be functioning, I have no idea what else to do. I'm about to pull my hair put. Any advice on next steps would be greatly appreciated. Thank you.
