Coil part number needed
glenn2
Hello
I have an old hayter 21 rough cut with the orange briggs and stratton engine .
I need a replacement coil but am having no luck as I cant find a part number for it.
Can anyone help me out
Thanks
Fish
Hello
Thanks
You will want the newer style coil with the electronic chip added, as it did away with the points. What are the model numbers of your engine?
glenn2
I cant find any
Model, type and code numbers should be stamped in the shroud, just above the spark plug.
glenn2
Didn't realise for dirt and rust
hlw49
397358 new style magnetron ignition module.
