Can not get the drain plug out of the hose.
Mike69
On my DeWalt Z148 ZTR mower I am trying to change the oil because it has gas in it, & I cannot get the drain plug out of the drain hose. I tried to put 2 wrenches on the hose & the plug & the hose keeps moving & I cannot break loose the plug to drain the oil. Any ideas?
Mechanic gloves to protect your hands & knuckles. Two 10" crescent wrenches one pushing the other pulling for leverage squeeze together to break loose. You will need to remove carburetor for repair before starting engine with new oil & filter.
If still under warranty let Dealer repair carburetor.
Thanks for the info & tips I was able to finally get the whole hose out of the engine & clamp it in a vice & it was a fight but I got the plug out.
I use a Vacuum Tool I purchased from Harbor Freight to suck the oil out of the Riding Mower’s. This allows you not to have to use the drain plug on the motor.
I would get someone to help hold the hose and back up rinch. Then use a impact rinch on the cap on the end of the hose.
  • Like
Reactions: Cfs
