Ivor_Wolf
- Mar 4, 2023
- Threads
- 1
- 2
I have an older ds craftsman riding mower with a model: 441777 type: 0785 E1 Code: 061011YG motor. My father has put in a new starter and new battery over the years and we keep having the same issues. It will start up and run but it does run a little rough. However, if you shut it down and then try to turn it on again the starter cant turns the engine. If I manually turn the engine past the compression stroke then it can turn on the engine. I checked the timing and it is good and I was gonna go look at a compression relief valve however I cant seem to locate one online for this engine and I've seen people talk about this specific engine not having a mechanical one. If anyone could toss me ideas as to the starting issue that would be great. We have been chasing this for years and wed love to get it fixed.
