Need Governor Arm And Springs
69Spiderman
I have a Troy Built 6250 generator with a 13hp 420cc Briggs and Stratton engine model number 30594A that I need a govenor arm and the springs to go with it. I've tried Briggs and Stratton, Jack's, Ereplacemennt and numerous others to no avail. Anywhere else I may look? Thanks for the help
First you need the engine's model, type, date codes.
The model post is not a model number but is a conversion kit.
69Spiderman
All of the stickers have been power washed off. I looked under the engine cover on the ohv plate and cannot find the numbers anywhere
Okay a little off here the generator model number is 030594A and not 30594A. Should have a 1450 series engine.
The model, type, and datecode should engraved at position "A" on the crankcase. Should be something like 25P132-0003-G1.
BTW what in the heck are you power washing a generator for. It is an electrical item and can be shorted out.
69Spiderman
25U032-0001-G1
I got this for free from someone that couldn't get it started but I got it to run and it puts out power just not governed power thanks for helping
Okay currently Briggs does not provide the governor arm and springs part numbers for the 25U032-0001-G1 per Briggs Power Portal and their Eparts site.
  • 25U0320001G1~.pdf
69Spiderman
I really appreciate all of the help you have given me but none of the governor parts are available on there. Are there any salvage yards for generator's that you know of
This has the manufactured by Generac and marketed to Briggs with licence to Troybilt vibes. Or a Briggs while falsely claiming to buy Generac while stealing their technology paths.
It is a complicated history. Yes for about 10 yrs Briggs had exclusive right to the Generac portable generators but that expired in 2010. And apparently after Briggs filing Chapter 11 things have gone South for the consumer that had portable generators made by Briggs. I don't know if this engine was made for Briggs or Generac but it does have the Briggs model number format.
https://www.archute.com/who-makes-generac-engines/
It is a crying shame no one wants to fully support the engine or the generator.
On top of that it appears to me that Briggs is going completely out of business as way too many parts are becoming NLA lately.
