bslow47
- Jan 8, 2023
- 12
My Flip up will not flip up anymore. I insert the pin in the lower switch on the deck rail, which kills the deck from moving as it should. I pull the lever in the back, which (dis)engages the other switch, and nothing happens.
I took that switch out and ran a continuity check, which checked out fine. Deck height adjustment works fine. But I can't flip it up anymore. Does anyone have ideas? Thank!
