Hustler Sport remove front tire
Headbo100
How do I remove the front tire on a Hustler Sport? The wheel has a slow puncture. I have undone the nut on the shaft that holds the axle in the fork, but I can't get the bolt out to allow removing the wheel from the fork.
Any help would be appreciated.
It is probably rusted in place and need to be driven out with a punch. Then the bolt #4 and the spacer #5 replaced.
You'll need a bigger hammer.. Try Kroil penetrating oil, works wonders getting stuff unstuck. r
