grumpyunk
- Jul 13, 2015
- Threads
- 0
- 154
The fuel outlet inside the tank is getting clogged as the fuel falls into the tube leading to the fuel line. You may be able to remove the outlet(or not, depending on design) and clean up the schmuz, or will have to see if you can flush it out after removing the tank so you can position it to allow the stuff to get out with the flush.
tom
tom
