Running very rich and missing
Are the valves moving proper? Time to pull the valve cover and see. Push rods where they belong?
There are 2 TDC strokes on a 4 stroke engine. Could of set valves wrong.
Something is getting missed. Or some "new" part is not working proper.
Grassman69
I checked and adjusted the valve lash. It was almost perfect anyway. I agree, I'm missing somthing and darned if I can figure it out !
Grassman69
UPDATE. I found the problem and I feel really stupid. The new carburetor came with the wrong gasket which allowed it to suck gas directly from the bowl. Installed the correct one and it runs like a champ
sgkent
do a cylinder balance test.
