Dewey Nunez
1969 Yazoo 24 inch big wheel need a blade -- Yazoo 24 inch big wheel Need a flat blade 24" walk behind -- I have pictures
Thank you I need a straight 24" blade needs to b slotted havent located rectangle hole please send me the number if you get time ..Thanks Dewey 713 203 9435 cellDo you have a blade like this.
- Length 24-1/8"
- Center Hole: 3/4"
- Width: 2-1/2"
OREGON 91-142
OR do you a straight blade with a 5/8 center hole.
and some these actually had rectangle center hole.
which is NLA other than old stock in someone's shed from what I could tell. Looks like:Yazoo 206-224
Good luck
76" X 3 - is that the hovercraft model?I got a set of left hand 76" blades for my yazoo about 10 years ago and they were $60 per blade. $180 for a set.
