Yazoo 24 inch big wheel Need a flat blade 24" walk behind -- I have pictures
Dewey Nunez
  • / Yazoo 24 inch big wheel Need a flat blade 24" walk behind -- I have pictures
1969 Yazoo 24 inch big wheel need a blade -- Yazoo 24 inch big wheel Need a flat blade 24" walk behind -- I have pictures
You don’t provide us with much info. Have you got any model and serial numbers for the unit?
Do you have a blade like this.
  • Length 24-1/8"
  • Center Hole: 3/4"
  • Width: 2-1/2"
OREGON 91-142
OR do you a straight blade with a 5/8 center hole.
and some these actually had rectangle center hole.
sgkent
from an online PDF and at Jacks 0206-624 if it is a SV24B. A facebook post in a Yazoo forum someone said they get theirs custom made because they are slotted. One Yazoo blade for another had a rectangular hole. Might have to change the blade mount to use common blades.
Here is a photo of a Yazoo blade adapter from online. Does it look like this or are we in for some spam soon?
Hammermechanicman
I had a 76" Yazoo HPTOK that had that blade adapter. They are prone to breaking and i had to make my own as i could not find any on the web. Yazoo made lots of left hand discharge mowers so they need left hand blades.
Dewey Nunez
  • Length 24-1/8"
  • Center Hole: 3/4"
  • Width: 2-1/2"
OREGON 91-142
Thank you I need a straight 24" blade needs to b slotted havent located rectangle hole please send me the number if you get time ..Thanks Dewey 713 203 9435 cell
Hammermechanicman
Yazoo 206-224
Good luck
Hammermechanicman
I got a set of left hand 76" blades for my yazoo about 10 years ago and they were $60 per blade. $180 for a set.
sgkent
