davbell22602
- Nov 27, 2011
- 1,324
I guess the only thing left to do is to replace the carb since theres no fuel/air mixture screw to adjust.
Those ultrasonics are not the end all of carb cleaning. You have to do it maybe 3-5 times and if then get a good clean on one.I already cooked it for a hour in a heated ultrasonic cleaner. This is the nikki version not the walbro. Only adjustment is the idle screw. Rebuild kits dont come with a new seat. Seat isnt removeable.
Watch videos of other people using them on carbs. They state you have to recook several times. Better tools out there that offer instant heat and are much cheaper if not free. Keep using an ultra cleaner. Doesn't seem to be working for you. Good luck with it.I find that hard to believe about ultrasonic cleaners. I know experienced shops that been in business for over 30 years that use them everyday with success. Dont have a working stove or crock pot. Im just gonna replace it. Thanks for the help.
top speed with half choke is 32xx. With no choke when surging is 2800 to 3100I might consider putting a tachometer on it and see what the RPM actually is at the top speed. The half choke can be making it richer, or it can be slowing the engine just enough to stabilize the governor system from oscillating.
