Ponytailoftexas
I have a 2013 Bad Boy ZT Elite Serial #BZE6027KO01131827 with a with a Kohler 27 hp serial #4214624103 motor.
For the last several months, the mower appears to not be charging the battery when running/mowing. I have had to a repair place twice and the most recent time, 03-31-2021 he replaced the "rectifier, starter solenoid and starter and serviced it oil/filter change, 2 spark plugs". Previously, he replaced the connector to the steering arms and a fuse.
The first time we mowed with it following that repair, it mowed for about 3 hours and then died in mid mow. Changed the battery and it mowed another 2 hours and then I mowed yesterday for about 2 hours. Today ... would not start ... battery dead ... again. UGH
The repair guy thought maybe the previous uses had damaged the original battery which is why we put on a different one but, now it's done it again.
Any ideas what else could be the issue or what else he needs to try? I've been surfing the web trying to find helpful hints or posts and so far, we've already done the suggestions that I've seen. Any input is appreciated!
