spitfire0450
I have a Craftsman 4n1 yard vacuum with a B&S engine#123k02-0240-e1. Ran great last year. Took it out of the shed, checked the oil(replaced last fall) good, added gas(ran stabble last fall till it ran out), cleaned spark plug regaped to .030, cleaned air filter with air comp. Started right up let choke run till it was warm then took choke off. Ran for another minute and died. Started up again full choke, then no choke and started to die put back at full choke started up again then died. Took carb off let everything soak in cleaner for 48hrs. Took wire to all holes made sure nothing was clogged. Then spray carb cleaner to all holes. Air comp. all holes too make sure no clogs. Emptyed gas container checked hose (no fuel fliter) cleaned with air and tank also. Re-assm check float to see if gas is steady (YES). Start up same issues. Changed the plug. Start up same issues. If I play with the govener lever it will catch and not stall. Also if I leave choke on it will all most die but doesn't. Took off the cover looked at the govener arm looks fine. Bought a carb kit but the only thing I did not replace was the needle seat gasket. I used powerequipmentinfo.com too make sure I re-assm everything correct. Any other things I should look at or try?
