- Sep 24, 2017
- Threads
- 277
- 6,745
Definitely running lean either cause of a air leak past the carb, or still, dirty carb... Could be a tiny crack in the intake manifold as well.
No, rust has nothing to do with magnetism.Is that too rusty for the magneto?
It was stuck and I pulled too hard.How is the spark plug wire attached to the terminal on the plug? Looks like a bad plug wire off the magneto. That would explain the quick surge.
