Old 361 dixon...12 hp B&S
So I need to use a releasing agent? wd 40?
WTF? For what? Getting the seat out of the carb?
WD-40 is basically a solvent with a small amount of oil.
Boil clean the carb. Pull it from the hot water. See if the seat comes out easier from the heat.
I made a puller to pull them out with. I work at a hardware store and have a lot of resources to make things like that. I took a bushing that would fit over the seat and took a tap that would thread the inside of the old seat. Then get a screw that is long enough that you can screw into the old seat and stick up above the seat. Thread a nut over it and put a washer between the seat and the nut and pull it out. Then you always have one to use.
WD40 water dispersant 40th formula. Not a good lubricant.
The 'seat' in the Briggs and Stratton is solid with a hole in it. I believe I can get it out ok. Just
wanted to see what others would do.
Yeah I've some small self tappers with hex head and captive washer. I think I've had it out before when I put a new
kit in it. Seems like it then had a small "o" ring instead of the 61323.
