Kohler ID?
gregjo1948
I got in, to repair, a Ferris 3- wheel mower, model 5900701--serial 2012629507. It has a Kohler 2-cylinder engine with no ID tag on it. It has cast iron sleeves in the cylinders, hydraulic lifters, and it is carbureted. The cylinder bore is 3.263"(best I could measure). Can anyone identify this engine so I can order parts for it? Thank you, gregjo1948
Can be any one of the 7 following 27hp Kohler engines that were spec'd to Ferris>
CV740-0009
CV740-0035
CV740-0043
CV740-0044
CV740-3112
CV740-3113
CV740-3130
gregjo1948
CV740-0009
CV740-0035
CV740-0043
CV740-0044
CV740-3112
CV740-3113
CV740-3130
Do all these models have the same bore and stroke? All have hydraulic lifters? All have cast iron liners/sleeves? All carbureted, not efi? All 1 1/8" crankshaft? All vertical shaft? thanks, gregjo1948
