Craftsman tractor 917.289272 Briggs and Stratton engine revs a uncrontrollable top speed.
The holes on the ones I have had were wallowed to bad to fix like that.
Then getting the alignment right will take a jig so that a bushing can be installed.
The question here is why the shaft failed in the first place? Something had to cause it. Personally I have yet run across an engine with this problem.
How long you been doing this? They seem to have fixed the problem but back when the Intek first hit the market they had a lot of issues.
