Back in about 1969 we had one of the first sears Eager 1 mowers. No deadman on the handle. The only control was a toggle switch on top of the engine shroud to kill the ignition. Push the primer and pull the rope and it ran at full speed till you flipped the switch. No idle circuit in carb so that is not a new idea. I have had people want me to "fix up" a throttle control on those fixed speed trashcumseh mowers. Sorry.
