Hi,
I'm looking for a carburetor for my walk behind front wheel drive Poulan Pro lawn mover. The part number for it (from Poulan Support): 16100-Z870510-0009, The strangest part is I could find it any reference on the web. (with exception of https://www.jackssmallengines.com/j...v175-7-0-8-0-ft-lbs/rv175-carburetor-assembly)
The other strange part is the model on the carburetor itself is Z870210-171028-R and made by "SP" ... From the Poulan support the engine is made by Rato. I tried to take it apart and clean it but the bolt/not that hold float bowl seen to stuck. Anyone know if it can be removed the bolt and where I can find a replacement.
Thanks,
Thanks,
