PTmowerMech
- Apr 16, 2018
- Threads
- 431
- 3,301
Troybilt Super Bronco 13WQ93KP011
Kohler KT735-3012
Replaced fuse, and blew immediately. Removed the + battery cable and replaced it again. Blew as soon as I reconnected the battery
Removed the voltage regulator connect, replaced the fuse (ran out of 20's, used a 25) Plugged the regulator back in, reconnected the battery, and it's all good.
Except the lights wouldn't go off. And the engine wouldn't start. So, I tested the key switch and it's bad.
So my question so far is, could the key switch be causing the short that's blowing the fuses?
I still haven't checked the regulator yet. I'll get to that when I get the switch replaced.
Kohler KT735-3012
