That is the correct line drawing. I am not sure how to go from there. Where is the alpha-numeric type code found on the engine? All I see is a sticker on the gas tank that has the info I typed above.See if you can find the alpha-numeric type code for the engine. So far I got it down to a GCV160A0 but there is about 30 type codes. I see the crankshaft drawing and the 06131-Z8B-W50 does not appear to be the correct crankshaft.
But the measurements given it appears to this crankshaft's line drawing that you are looking for.
