Bphillippe
- Apr 29, 2022
- 3
I have a Honda HRX 217 G5HYAA mower that I replaced the crankshaft on. The guy who had it before me hit something and beyond the shaft. I got it torn apart and replaced the shaft and cleaned everything up. Use the Honda seal material and got the mower back together. We used a drill to test it first without the spark plug in and it turned very smoothly and made no noise except for the compression of the piston. When I placed the OEM spark plug into the mower and tried to crank it again there was a knocking sound inside of the crank case. We checked all the timing marks and the lifters and the sound did not come from that area. I even removed the lifter cover and listen to it has he turned the motor. I’m Trying to find out if anyone has had this happened or what you think I should do next.
