Belt slipping or transmission gone bye bye ?
Piney
Older Craftsman rider
Drive belt finally broke. I replaced it with OEM part
I don’t see any tension adjustments
It will now go on flat lawn but no longer up slight hills
Belt slipping or transmission finally gave up the ghost ? How would one tell?
Scrubcadet10
Moderator
Staff member
Could you post the Model number of the mower? Should be on a tag under the seat.
Some mowers have 2 drive belts. On from engine to trans and one on the trans. Usually called a lower drive belt, IIRC.
mechanic mark
Put rear end on jack stands with belt installed & give it a go. Also check idler pulleys for drive belt by removing them & check center bearings for wear by spinning them by hand. If you hear metal noise or rattling replace idlers Post 917....... model number from under seat & any numbers from transaxle.
Piney
917.376731 Model # plate
I didn’t notice idler where’s binding when putting on belt. I’ll check
Scrubcadet10
Moderator
Staff member
Hmmm. 917.376731 is coming up as a push mower ?
Now Scrub it is a new type of riding mower....:LOL:
Piney
Scrubcadet10
Moderator
Staff member
Don't know what to tell you... could you post a picture of the model tag?
