cruzenmike
Hello.
Local gentlemen is selling an early 2000's Cub Cadet 3206 for $1200. The machine has 750 or so hours and he states that it starts right up and runs well. It comes with the 54" mowing deck. This machine has a 20hp Kohler Command Engine, shaft-driven hydrostatic (with larger pump and cast iron axle), locking differential, hydraulic power steering and hydraulic deck lift.
Supposing everything works as it should, and there are no visible leaks of any kind, is this a good price for this machine? What should I be looking for when I go to inspect it?
I have some reservations about a 20 year old machine with a bunch of hydraulics but for what I intend to use the machine for (hauling stuff), I would only expect to give it about 20 hours of use a year.
I appreciate any help you can give.
Mike
Mike
