omerta14
 - Aug 12, 2017
- Threads
 - 5
 - 21
Hi.
Baffled by why my YT3000 21hp ohv(model 331977) won't start without a squirt of starting fluid. Over winter I replaced the head gasket as it was blowing smoke. I reset the valves clearances according to specifications and buttoned it up.
Went to start it this past week and it slowly cranks but will not start. (Battery fully charged). I eventually ended up spraying a bit of starting fluid into the carb and it fired right up. Stays running and runs smooth as silk. Shut it off and come back...same issue...will not start without a hit of spray.
No idea what it could be....It always started fine last year, just smoked like crazy.
Thanks for any guidance!
Mike
Mike
