crazy charlie
.Mod 20436
ser 3907024. B&S motor.5.5 Thanks for the previous help on my "Which spark plug " post.This new to me Toro seems to only want to run for
5-10 mins and cuts off.I replaced the air filter,spark plug,changed oil and dropped the carb bowl and cleaned the lateral jet hole.
carb bowl was cleaner than I expected.Actually very clean.Lateral hole had a tiny crud in it .top hole does not seem like an actual hole.
Seems more like a fitting?? Could not poke anything thru it.Kinda puzzled so I put the old plug back in and it is doing the same.
Made a fuel cocktail with Berrymans Chemtool,Chevro techron,and Seafoam and let it run through the system with gas for cleaning.
Kinda puzzled.BTW,it does not immediately restart.5 mins or so then it starts on choke.Everything connected to carb/throttle seems connected
and moving with throttle handle accordingly.Hmmmmmm Charlie
