Ya think he needs new blades
Hammermechanicman
JD Z245. This is one season on these blades. Guy lives on a farm. I just finished scraping still wet grass from last season out od the deck. It was packed so bad the grass was down to the blades. Had to use a pry bar to get most of it out.
fescue
Holy cows, does he till with these blades?
Hammer you going need to go on a diet. Look what you did to the concrete slab.
Have tried installing heat treated blades. They usually last twice as long as regular blades.
Hammermechanicman
I bought JD OEM couple years ago. They were not like the Marbain blades most JD mowers have. They were just like an OEM Oregon or MTD blades. The Stens AM blades are only $8 apiece so i just put new ones on each year. I am suprised how well the mower has held up with what he does to it.
7394
I like the Marbain steel ones on my cutter..
sgkent
I think his cows need a little less roughage in their food.
Appears that the Z245 has a 48" deck; therefore, a set of A&I's 7 lobe XTH A-B1JD6017 blades would be what you need as they are made with Marbain. XHT (Xtreme Hardness & Toughness) blades feature a unique steel that incorporates boron, carbon, manganese, and other materials that ensure its strength. The blades are heat treated with a process makes the blades 25% - 40% harder than standard lawnmower blades, making them the longest-lasting, safest, and most impact resistant lawnmower blades on the market.
I used them until recently due a problem with A&I taking so long to respond to my emails and lying to about calling me. They are very good blades and usually last twice as long.
Hopefully I finally got that straighten out or they going to lose me as a dealer. It cost them most their sales to me last year. I went from buying over $3K yearly to $425. Another I have with is the way they did on shipping charges which can eat you alive below the $200 free level. I kinda mean now as I make double sure I buy at least $200. Example: $200.02 so I see a charge of $46 in shipping charges again.
I just starting this year's purchases. But it is going to be hard to meet the $2K yearly purchase minimum as I now got work out all the replaced parts of theirs before I can buy their parts again. Plus they have another problem as most their parts are higher than their competitors. I also had a problem that I could never get straighten out about their after market v-belts they all come in shorter than the stated sizes. I just had quit buying them even though they were good belts due to the sizing issues.
Hammermechanicman
I looked at A&I and some other distributors and decided to just go with stens as my AM parts supplier. Shipping is reasonable at $10.50 below $150. I am not big enough to meet some distributors minimums if i spread it across multiple distributors. I did get a commercual tax free mechanics account at o'riley auto parts and i am tax free at the local JD dealer. For OEM parts i just go with a large online parts supplier and pay retail. Thanks for the info on the good blades.
