LawnWizard
I am going to replace the Kawasaki engine on an Exmark Pioneer E series 48" that I bought from a very dishonest POS online. It's a long story but regardless, he posted a pic of the spec tag which showed an FX 730V-CS12. The engine is actually FR651V (according to the air filter cover) and locked up about an hour into the first use. So, my question is: I know that my FX 850s and FX1000's all have 30 AMP charging systems. How do I determine which spec 651 - 730 engine do I order for this mower? Is it a 15 /20 OR 30 AMP? There has already been some hillbilly wiring on the mower (separate kill switch wired in) and the harness has more wires taped off than used but I can sort all that. I would like to return this mower back to original as much as possible with the correct engine (or slightly larger).
The VIN is: PNE651KA482 so I assume it came with a 651 but again, without the proper spec tag, I don't know which spec to order. BTW, I'm a Hustler guy so please forgive my Exmark ignorance.
Thanks in advance for any help / suggestions!
