I recently picked up a craigslist $25 1995 Snapper RP21550E electric start self propelled mower. Filthy and neglected. Briggs 5.5 Quantum engine, starts easily by pull rope, runs great after installing new carb, air cleaner primer backing plate, and spark plug. I checked all the connections, installed a new battery, and no crank.....I removed the starter, found that it was hard to turn by hand. Got it freed up, then applied 12 volts to it, voila, it spins. Noisy but spins. Reinstalled, put new interlock switch on, still no crank. Swapped ignition switch with a known good one, still no crank. Battery is charged. I don't know what else to check other than I'm guessing there is something wrong with the starter. $125 to get a new one, ouch! Hoping someone has some insight. Thank you!
