Mower starts but does not continue to run... VIDEO UPDATE last page
Fish
  • / Mower starts but does not continue to run... VIDEO UPDATE last page
Even with my new coil installed, I don't seem to be getting any spark. Still troubleshooting.
What coil did you put on it?
Fish
And, how are you checking for spark?
Clippy
Scrubcadet10
Moderator
Staff member
With that coil, with No kill wire plugged to it, it should spark for close to eternity.
Clippy
Still doesn't seem to do anything with the kill wire unplugged. Think they shipped me a dead unit?
Scrubcadet10
Moderator
Staff member
where did you buy it from?
Two things to check
1) check the kill wire for voltage
IT should either be open circuit or ground if it has ever had voltage on it then the coil is toast and the wiring problem must be fixed first
2) are you sure you installed it right way round the trigger chip is polarity sensitive .
Clippy
UPDATE: I bought a new coil from a lawnmower shop and it turned over! The same coil worked. They must have shipped me a dead one. Now I just need to figure out why it shuts off after about 3 seconds. My guess is its not getting fuel or the carbs need adjusting.
Clippy
This butterfly valve is the culprit. It stays open, and when I close it about half way it runs great. I think I hooked up my carb linkage backwards. I'll update tomorrow. I'm just really happy I got it started tonight!
Carb linkage is set up correctly, need to figure out what's going on with Choke plate
Fish
There should be an adjustment screw on the bottom of the carb, turn it to the left as it is running to see if it runs better.
