mower moves slow after changing drive belt
masteretectech
I changed drive belt after changing fan above tranny and it doesn't respond like it did before. hard time going up hills.
If the correct belt (length and width) is on the idlers and other pulleys it is unlikely that it is slipping unless your pedal needs adjusting.
Be sure the fan is the same Pulley size as original Hopefully you will not require a new Tranny. I did !
