Richard Milhous
- Aug 2, 2021
- 173
I have an old Murray push with a Briggs 95902, 1992 vintage. The starter pulley wore out where the recoil spring goes in, causing the spring to come loose and get scrambled up in its housing. I found a new spring and pulley, but can't get the spring to stay seated in the shroud.
I can't find a part number for the shroud or even the whole shroud/starter assembly. I have a good shroud/starter off another carcass, but the pulleys and the connections to the flywheel are different. The worn out shroud (Exhibit A) has a 4" pulley that takes the old squarish ratchet cog on the flywheel. The good one (Exhibit B) has a 4.5" pulley from pawls come out when it's rotated to engage a fixed cup on the flywheel (Exhibit C).
I thought I would just replace the ratcheting cog (Exhibit D) with the cup, or at worst swap out the whole flywheel, but the dang crankshaft on the one I'm trying to fix has a mandrel that goes into the ratchet (Exhibit E). I'm tempted to slice it off and use the other shroud, but before I do anything so permanent I thought I'd ask if anyone...
(1) Knows a way to replace the old shroud;
(2) Knows a reason not to slice that mandrel off the crank;
(3) Has a better idea for solving this problem.
