Dana-transaxle d4360-140 input bearings
Community Leader
Location
Pluto
Just wondering what the correct bearings are since the ones suggested on the net are not the correct ones.
See item 15, Input shaft assy. kit, part # 6250.
Thanks but I'm not that desperate. I can always install an complete used unit for $120 plus tax which I got sitting on the shelf. I just needed the two bearings which I found out which 3600 lb bearings they are shortly before closing and they be here tomorrow for less than $20 including shipping. A heck a lot better than $160. And I will nearly double my money on the parts alone.
I even found the Dana 174256 anti rotation washers for $0.99 each through cross referencing. Too bad Dana want to list them as NLA even they are available through my distributor. Just got to know the right part number that they are currently available under. ;)
Can you tell bearings type that you ordered? Thank you.
